need new prop
apache61
Took the boat out this weekend to fish and run the Grand kids around on the water. Was getting 40mph with me and the Admiral, at 4400 RPMS, with us two other adults and the 2 little ones it was 38 MPH at 41 - 4200 RPMS. My currant prop is 14X23 on a 150 Mercury came on the boat boat. I am thinking I should go with a 19 pitch, any ideas?
Boat details are 2001 Trophy 1900FG Duel Consolel.
Length Overall (LOA) 19'0"/5.80m
Beam 8'2"/2.49m
Deadrise 19°
Approx. Weight (w/Base Engine, 125 Mercury) 2,493 lbs/1,132kg
Length Rigged 21'0"/6.41m 23'6"/7.17m
Height Rigged 7'6"/2.29m
Draft Hull 1'4"/.41m
Draft Max 2'9"/.84m
Bridge Clearance Max 4'3"/1.30m
Fuel Capacity 55 gal/208L
Dhadley
Re: need new prop
Since it's severly overpropped now you could possibly go to a 17. Anything with less pitch will be better.
What prop do you have now? Aluminum or stainless? 3 blade or 4?
apache61
Re: need new prop
Thanks for the reply. Its a Mercury Black Max aluminum. Yeah I know its over propped I used the prop wizard and a few other prop guides they all came up with either a 14 1/4X19 for overall performance and a 14 1/4X17 for tow sports. I use the boat mostly for fishing, only towing a tube around a few times a year.
usskydvr
Re: need new prop
I think you have already answered your own question. Good Job!
Dhadley
Re: need new prop
If I were doing it I would think about a 17 4 blade, if you were thinking stainless. You could then raise the motor a little and gain overall.
apache61
Re: need new prop
A few pic's of the boat and motor setup. The motor is already set up 2 holes, the cave plate is up from even with the bottom a few inches. On tight turns it loses it bite. I don't think I should raise the motor any higher any advice would be great full.
I am planing on going with SS that is why I am asking the questions here. Was planing on a three blade but maybe a four would be better. Just trying to get it rite the first time, SS coast a lot of $$.
Dhadley
Re: need new prop
Your motor is mounted about as low as it can be. Looks like the bolt holes were drilled lower than they should have been, that's why the bolts are not in the top holes. Anyway, engine height has more to do with prop design than anything. Since you can only go up one hole (about 3/4", maybe a tad less) a 4 blade may not do you any good without a jackplate. A good ss 3 blade prop will give you your bite in the turns unless you're trimmed up too much.
apache61
Re: need new prop
I can still raise the motor 2 bolt holes aprox. 2 inches, like you stated I don't think that will do me that much good. I really don't want to go with jack plate. I'm not trying to get every MPH possible out of it mainly looking for good performance and getting into the proper RPM range.
