1970 starcraft 25foot cabin cruiser help
mitchranger1
my future wife and i got the boat mentioned above a week ago and am trying to decide the best course of action to restore it. please if anybody has any suggestions feel free to give them thanks im kinda lost already
these are before we got to major demolition, just removing the seating..
mitchranger1
Re: 1970 starcraft 25foot cabin cruiser help
here we have removed all the seating and the majority of the carpet.
this may be obvious (sorry new to this forum) but if you click on the images, they do get larger..
chargerboy
Welcome to the forums! Really like that boat! Seems like you're on the right track, keep gutting out all the old rotten wood, and expose as much of the mechanical and structure as you possibly can for inspection. Once you can get around everything, it will be much easier to see what hidden problems there might be. I am no expert, but I suspect people will chime in to recommend replacing those fuel lines.
How is the engine/outdrive? Did everything work ok with the boat? Are you planning on restoring it the way it was, or do you have a new design you're going to try out?
Triton II
Woohoo... another Starcraft! But this time a 'glass resto so that's different from the usual SC alloy cult-members' boats. But don't worry, there'll be HEAPS of advice given as it seems most guys and gals on iboats either:
1. Own a Starcraft
2. Want a Starcraft
3. Are restoring a Starcraft
4. Are thinking of restoring a Starcraft, or...
5. Wish they could get an alloy Starcraft in Australia! :D
Welcome and cheers from the land downunder.
TII
mitchranger1
yeah im really excited about the resto. the motor seems fine havent gotten it fired up yet . im not getting any spark to the coil i did a complete tune up on it replaced the coil still nothing so gotta track that down any ideas guys and gals its a 73 chevy 350 motor
Huron Angler
Welcome to the Starcraft armada...we've been lacking a 25ft glass cruiser to add to the mix:)
That's easily the heaviest SC on the site, good luck with the project!
mitchranger1
thank you im gonna make it a floating r/v it had a sink and ice chest type thing that looks like a fridge and a head but im gonna put in a real fridge cook top and stuff like that redesigning the whole set up inside and out and next year im gonna put in a bigger motor im gonna post more pics of the demo soon if any body knows where i can get some stuff for my boat i would appreciate it thanks all
mitchranger1
Removed the walls around the head
Sink and cabinet before removal
bow of the boat
Where the sink USED to be
emptying out the cabin
jspano
nothing like a project boat to get a future family together. good luck, as mentioned not many glass starcrafts here but awhole bunch of good glass restores. read as many as possible.
Triton II
Hey Mitch,
I suggest you ask your engine questions on the Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives Forum - those guys are knowledgable and helpful. Cheers,
TII
chargerboy
If the coil isn't pushing out a spark, it's not getting power. Use a voltmeter and check the positive side of the coil when the ignition is on. If it reads zero, trace the wiring back to ignition switch, starting with a fuse. Problem lies between ignition switch and ignition coil wiring, to verify you can "piggyback" a connection lead from the battery to terminal on ignition coil. It'll fire up.
mitchranger1
cool thank you let me try it i will get back to you on the outcome
mitchranger1
well it was a no go on the jumper wire anymore suggestions
chargerboy
Then the problem isn't with your coil making a spark. Are you sure your points are set right? Your distributor cap has clean connections? Your wires are good? Your plugs are good? How did you test to see if there's a spark, and did you check for power to the ignition coil with a voltmeter when the key is in the "on" position?
mitchranger1
I replaced the cap, all the wires and plugs when I brought it home. I did check the coil with a voltmeter.
There is power going to the coil, but no power coming out of the coil.
chargerboy
If you have power running to the coil, your problem lies within either the coil, distributor, points, cap, wires, or plugs. What we know is good:
-coil
-spark plugs
-wires
-cap & rotor
Now, the only other thing left that needs to be checked is the points setup. Did you check them? Poorly set points will result in a no-start condition.
edit: Also, how is the grounding of the block? I recall one time I had a hard time starting my truck when the battery grounds became corroded.
mitchranger1
Future Mrs here... I will run this info out to him! He is all over the motor trying to figure this out! Thank you SO much for your help! :)
mitchranger1
Ok, he said the ground is fine. The starter is cranking. There is spark to the coil, but there is no spark out of the coil.
He said he wouldn't know the first thing about checking points, he have never had to mess with them.
Wingedwheel
I believe if you do a resistance check, testing between the output winding and ground you should get some resistance. If it reads open your coil is bad.
Wingedwheel
Also...Welcome to IBoats
