omc 7.4 GL running well on neutral, problem on load
olivier06300
My boat is a chris craft concept 27 CC, KING cobra. I'm French;
My engine is running well on neutral, 5700rpm very good. but when i'm boating i can't go up to 3000 rpm and the engine make a strange noise lan internal explosion and moving a lot.
Please have you an idea?
Olivier
OldNBold51
Re: omc 7.4 GL running well on neutral, problem on load
Olivier
too vague to make a judgement call. Revving in neutral tells nothing much at all. Check your firing order to make sure the spark plug wires are attached to proper spark plugs.
olivier06300
thanks OldNBold51 for your ansmer.
But My engine is OK on Neutral no problem of iginition, i have a problem on load when i boating i cannot go up to 3000tr/min, i can heard some internat explosion and the engine is moving a lot. sorry for my poor english.
Kind regards
Olivier
That engine will run on 4 spark plugs in neutral. You still need to check ignition.
Have you done a compression check?
6meter
Do as Bruceb58 says and if ok is what you're hearing popping through the carb? Could be a coil. In neutral means nothing.
Could be a coil.
Rule #1 Its never the coil
Rule #2 Its never the coil
RUle #3 Its hardly ever the coil
We should have a poll on this. How many people have replaced the coil and it didn't fix the problem.
olivier06300
@Bruce
Compression Ok,
What you mean on neutral the engine will on 4 spark plug ?
@6meter
the noise is note fire back in carb but like a compression sound ...
I will replace all my spark, and try it.
6meter
I replaced my coil in 2008 and just replaced it again this week. It fixed the problem both times. Different symptoms each time.
Then you should figure out what is blowing your coil. Either it has improper voltage(no ballast resistor) or your spark plugs are gapped too wide or you have faulty wires and or distributor cap.
Icefire55
best thing to do is a regular maintenance (change plug and wire, look at your cap/rotor if good) retime the motor, if it's pinging (explosion noise) it's probably too advance.
Load probleme after 3000 rpm are normally 4 barrel carburator which the secondairy have problem (too lean, plate stuck) it just happened to me on my 350, secondairy plate stuck, sluggish after 3000
I speak french if you ever need something explained in french, I doutb I can talk french on the board.
olivier06300
Hi Icefire55
ALors je vais parler fran?ais, sorry for my english speaking friends,
J'ai chang? les bougies, les files de bougies, la t?te de delco et le doigt d'allumeur.
Toujours le probl?me, j'ai un allumage EEM, est qu'il y ades mise en s?curit? du moteur ?
Quand je prends la lampe stromboscopique je voie des coupure d'allumage quand le moteur fait du bruit et je vois aussi l'avance qui bouge, pas stable.
Le problem ce fait uniquement au neutre
C?t? carburation tout semble ok
Merci d'avance
Olivier
olivier06300
Ok i have fix the problem.
So the problem is the sensor of temperature, not for the indicator but for the alarm.
Thanks every body
Olivier
