EZ Lube spindle availability?
texomatom
Suffered my first bearing failure yesterday which resulted in a ruined hub and spindle.
I have a factory trailer with EX Lube spindles welded to a rectangular tube axle. I'm having some difficulty locating a replacement spindle. I have found complete axle assemblies, but not a replacement, weld on spindle.
Any one know of a supplier for just this part?
Thanks,
Tom
texomatom
Re: EZ Lube spindle availability?
Thanks 45.
I'm not seeing a direct replacement for my spindle on this page. But it does give me some more info to go with. After pulling mine apart I can see I don't have true EZ-Lube spindles. Mine use a cotter pin and as far as I can tell the EZ-Lube spindles use a locking tab on the washer/keeper. I believe mine are sure lube or ultra lube spindles.
I'm going to look for replacements but will most likely take my axle to a local RV dealer with a service department and hav ethem weld up a new one. I want to make sure it's welded properly and aligned true.
Appreciate your reply.
Tom
