OhioCatman
- Joined
- Jun 28, 2010
- 2
I recently purchased a 1988 Bayliner Trophy 17 ft with a 85 hp Force outboard. The problem I am having is rather strange. The motor always fires right up, idles with no problem, goes into gear and everything with no problem. The problem only occurs when running @ WoT on a plane for about 15 min, the motor sounds like it flutters and then all the sudden will drop to idle rpm and even sometimes immediatly increase rpm back to normal WoT. Motor does not die at all when this happens, it just drops to idle rpm. I replaced the fuel line and primer bulb going from the water seperater to motor after the first time I took it out and it did this as I was thinking it was maybe sucking air into the line or even water. I took it back out a couple days ago and it did the exact same thing, took almost exactly about 15 min again before it started doing it. Thanks in advance for the help.
