fouroaksphoto
Thread starter- Joined
- Jun 28, 2010
- 5
My setup: 2008 240 Sun Deck on a Shorelandr' SLB58T 5,800 lb rated trailer. Boat and trailer weigh in at about 6,800 lbs. UFP Disc brakes on both axles. My brakes have been running hot and found that the pushrod release bracket on the UFP actuator was bent and holding the pushrod in place applying some brake pressure causing the brakes, hubs, wheels to overheat. Left rear axle seal threw quite a bit of grease, others not too bad. Disassembled actuator, straightened release bracket, reassembled, bled brakes, took on 7 mile test hop. Brakes and hubs warm but not nearly hot. On 15 mile (one way) trip from ramp Saturday I could keep my hand on the hubs but still seems too hot. On other threads some say 180-200 degrees is OK for hubs. UFP website shows a graph with bearing temps. running at 260 degrees. What is a reasonable temp. and what is not? Thanks!
