I have an 86 125 force. finally got it running after alot of trial/error mostly error. took it out for a quick trip across the lake the other day. it would scream! hit the trim and we really took off, the lake was smooth as glass. went out today and it ran good and steady at about 1/2 throttle @ 25 according to speedo but @ wot it would bog and my friend sqeezed the bulb and it picked up a little but not like it should. I have replaced; chec valves 3, diaphram and gasket, found recipt where carbs were rebuilt 3 mos ago, i have had the bottom carb off because it was leaking from the top of the bowl, i blew some air thru it seemed to be clean and clear. not sure what kind of shape the top carb is in looking thru the throat looks clean. could a float be the problem? how do you sync these carbs. i just made sure everything was in the closed or what looked to be the natural resting place for the connecting rods, with manual operation, everthing appaered to be operating in time together and smoothly. i have the idle mixture set at 1 1/4 turns from lightly seated per manual specs any help would be appreciated
