White Wizzard
Thread starter- Joined
- Jun 28, 2010
- 9
I have an 03 Crownline 230br with an EFI (TBI) GM 5.0L. Engine is freshly rebuilt and has the following parts new: coolant temp sensor, iac, fuel pump, both injectors, regulator, plugs, cap and rotor. Fuel system had a bunch of water in it. Sucked all the water/fuel out and filled back up with fresh fuel. Boat starts right up and runs for about 10 seconds and then acts like it runs out of gas. You can keep it going by giving it more gas, but will still die eventually. Had some venting issues with the tank, but they are fixed and still same problem. When it finally dies a little bit of "smoke" puffs out of the flame arrestor. Any suggestions would be greatly appriciated
