Danger! help! Cant turn the wheel back under power
broken08
Hello and thanks in advance. Newish to boating.
1978 Larson bowrider, merc io 165hp alpha1 non-power-steering
I have been getting this boat up to snuff and lubing up everything, now the wheel turns easily without drag, outdrive moves no problem. however while under anything above say 1/4 throttle if I make a hard turn (think picking up a downed wakeboarder) I can't turn the thing back. I have to crank super hard to the point I'm afraid I'll break the plastic old steering wheel, or let the power almost entirely off and then I can turn back.
I have recently swithed to a 4 blade prop in hopes it would help, but it didnt.
trim tab adjusted hard right without improvement.
I know it should be hard without ps, but this hard? no way, this is dangerous!
thanks!
Kainon
Re: Danger! help! Cant turn the wheel back under power
Which way is it hard to turn, left or right ? You may have made it worse by adjusting to the right, when you may have need it left.
I have the same problem once the boat cuts into a turn, i have a 21' alum and had a 1.98 ratio with a 23p prop and thought that was the issue, haven't been able to test since.
broken08
It is hard in both directions. The boat drives pretty straight too.
Kainon
Thinking about the problem.. hmmm..
One of the things i was going to do is try a Teleflex 4.2 Steering unit, versus the regular 3 turn unit, thinking I'd get a more mechanical advantage. My year didn't have Powersteering.
http://www.iboats.com/NFB-Rotary-Pa...8179703--**********.897206480--view_id.169492
  • The most revolutionary advancement in mechanical steering since the Teleflex helical cable.
  • Built with the same emphasis on safety, durability, and performance as the Big-T and Rack steering systems,
  • The newly designed No-Feedback helm unit locks out torque feedback from the engine to the steering wheel, reducing driver fatigue.
  • The precision die cast zinc helm unit uses the new QCII? helical cable assembly for quick and easy installation.
  • Features:
  • Patented No-Feedback mechanism
  • Compact rotary helm unit
  • Standard 3/4" tapered shaft
  • 4.2 turns lock-to-lock
  • Utilizes same bezels as Quick Connect Steering System
  • Exceeds A.B.Y.C. safety standards and N.M.M.A. certification requirements. Available in Single Cable for V4 & smaller, 50MPH or less and Dual Cable Systems for V6, 50MPH+.
  • Applications:
    • Steering wheels up to 16" - Boats up to 24'
