Does my electric start motor charge the battery?
Arkman
I have a 1968 merc 200 that has the ability to do electric start. I have not done this yet, just tested it to see if it worked. Now I want to hook it up but I'm wondering if this motor charges the battery or not. If not what kind of battery should I get. For that matter, what battery should I get if it does charge. I'm assuming a marine grade starting battery but I thought that might be different if it doesn't charge.
usskydvr
Re: Does my electric start motor charge the battery?
Sorry but your engine has a Magneto, so no charging capability.
Arkman
Ok, thanks. Thats what I thought. Does that change what kind of battery I put on it? Should it be a deep cycle since it will get drained before charging on a regular basis?
jmj120
My opinion is it wouldn't matter on the battery. Just put a trickle charge on it after every trip.
usskydvr
Actually a regular car battery is preferred.
Both car batteries and deep cycle batteries are lead-acid batteries that use exactly the same chemistry for their operation. The difference is in the way that the batteries optimize their design:
?A car's battery is designed to provide a very large amount of current for a short period of time. This surge of current is needed to turn the engine over during starting. Once the engine starts, the alternator provides all the power that the car needs, so a car battery may go through its entire life without ever being drained more than 20 percent of its total capacity. Used in this way, a car battery can last a number of years. To achieve a large amount of current, a car battery uses thin plates in order to increase its surface area.
?A deep cycle battery is designed to provide a steady amount of current over a long period of time. A deep cycle battery can provide a surge when needed, but nothing like the surge a car battery can. A deep cycle battery is also designed to be deeply discharged over and over again (something that would ruin a car battery very quickly). To accomplish this, a deep cycle battery uses thicker plates.
jmj120
Good points. Good advice.
