DerekBogie
Thread starter- Joined
- Apr 23, 2010
- 31
I took off my old sterndrive off my 1985 Baretta with a 4 cylinder 3.0 mercruiser motor. When i removed the sterndrive the gimble bearing came out with the sterndrive. it is jammed and stuck on the shaft that inserts into the motor. I do not care about that gimbal bearing as i took off the outdrive off my 1986 galaxy with the same sterndrive. i removed the gimbal bearing out of the transom assembly on the 1986 galaxy donor boat. I then installed the gimbal bearing out of my donor boat into the new boat transom assembly. Is there any seals or anything AFTER the gimbal bearing before the shaft enters the motor? Also is there a way you must insert the gimbal bearing? Like in a certain degree? One other thing. How can i align my motor without having to spend an arm and a leg getting it professionally done?
