1979 mercruiser IL6 165hp fuel filter??????
jos111
So I just bought this deck boat and was having some fuel problems after running at low idle for a long time. Thought I would change the fuel filter, however there does not seem to be one. The old gas tank was replaced with a 10 gallon tank and the lines run right to the fuel pump. There is no filter that screws out of the bottom of the pump. Where is the filter? Was it on the original tank, in line or built into the pump. Do i have to change out the whole pump. Thanks for the help.
zbnutcase
Re: 1979 mercruiser IL6 165hp fuel filter??????
If there isn't a small metal cup held on by a strap with a single screw on the bottom (or top) of pump, then only filter is in the 1 inch nut where the fuel line hooks to carb. I would install a water seperator filter if it was mine.
