Water overflow, normal or bad?
kriphead
I have a 1989 2-stroke 90Hp Mariner (3 Cyl) outboard. I just noticed that water is slightly trickling out through the top, not alot but enough to notice it.
It gives water fine through the tell tale and engine sounds good.
I have attached a picture which arrows pointing to the spot where water is flowing from.
Is this normal, or do I need a new gasket or something else???
Please help. Thanks
latin monkey
Re: Water overflow, normal or bad?
yes you need a new gasket, you will have to lift the powerhead to change it
kriphead
Ok Thanks. Is that something a novice/unexperienced boater could do, or should I let a shop take care of it?
latin monkey
its not very difficult at all for you and a buddy or if you had a hoist you could do it by yourself. its always good to have a manual though.
kriphead
Ok thanks. Any idea what the gasket is called or where I could find the parts #? I'm Danish so technical terms and words makes it slightly more difficult to find the correct parts (-:
achris
More fish than mountain goat
There are 2 gaskets there. Not sure which one is the leaker, but here are the numbers of them.
Gasket, Exhaust plate 27-430083
Gasket, powerhead 27-430073
Click HERE to download the service manual (Password for the file is <ribforum>)
Chris.......
latin monkey
exhaust plate gasket. you need the upper gasket thats fits between the powerhead and exhaust plate. do a google search for your motor or try ebasicpower.com or crowleymarine to look at some diagrams. hope this helps
kriphead
Thanks to both of you guys for fast responding. Highly appreciated!
Any idea what I should expect (dollar wise) if I let a Marine Mechanic do this?
Thanks again
K
