1990 225 evinrude stalling problem
jstrat7804
my 225 will run fine but when i slow down and put her in neutral
it dies. this will also happen when i try to leave the dock, could it be the timing? it will idle fine.
clanton
Re: 1990 225 evinrude stalling problem
Stalling when going into neutral= bad shift switch and bracket.
jstrat7804
thanks for the reply i will check that out.
jstrat7804
clanton- is that the name of that part, can't find it in my original repair manual. talked to a mech. he said spray the switch with a penetrating oil it has seemed to help quite a bit. thanks
jonesg
shift interrupt switch, the plunger gets sticky due to oil, dirt and gum.
RWStorbeck
I have the same problem on a 1997 Evinrude 225. I replaced the switch but the problem persists. The purpose of the switch is to cut out 3 of the cylinders in neutral so that you will go into the next gear with less of a bump. In my case I suspect that ALL of the cylinders are cutting out just for a second and the motor dies. You can bypass the switch and shift with all the cylinders. Just unclip the switch from it's bracket and try shifting.
jstrat7804
thanks for the reply, i took the switch out and cleaned it, shifted fine for a while then it started again. the switch does not seem to sit very tightly in the bracket, seems loose, also i think the idle is to low can i adjust the idle in the drive way or should this be done on the water?
