tilt switch on throttle will only lower motor, up doesn't work
winston the cat
My Mercury motor will tilt up and down using the button on the motor but it will only tilt down using the button on the throttle. I think it may be faulty wiring but I can't get inside the throttle to look.
Outsider
Re: tilt switch on throttle will only lower motor, up doesn't work
Keep looking, there's bound to be a way ... :)
BETZ954
not sure but makes me think maybe a bad relay??
Lewis
I had a similar problem on my 1987 Black Max 150. It was a bad trim/tilt switch in the throttle handle.
Lewis
seabob4
Do you have an O/B or an I/O? Side Mount or top mount shifter?
