itsaboattime
Thread starter- Joined
- Jul 4, 2007
- 791
I have just picked up a 1987 Evinrude 110 horse, model # E110tlcur. I started it up yeaterday for the first time and there was very little water coming out of the telltale. I had figured that would happen. I started it just to see if there were any issues. The powerhead runs great. So, I knew I was going to replace the water pump assy. when I bought the motor. Today I picked up a new water pump and installed it. Hooked it up to the muffs, still very little water.
My question, Water comes out of the water pump goes through the exhaust plates and to the top of the head water passages and down through the bottom and out the hoses to the themostat housing. From there it goes out through the exhaust.............right??
I get good flow coming out of the bottom of the water jacket on the heads. I removed the hoses to check. Could my issue be stuck thermostats?? They are the last thing in the system before the water goes out of the motor right??
Oh yeah I almost forgot, I have a seloc manual that doesn't address the cooling system at all other than how to change the water pump.
