archershindw
Thread starter- Joined
- Jul 2, 2010
- 7
Hello I am new to the forum and a new boat owner, 1st timer.
I have a 68 Johnson 40 hp electramatic that will not start. I have a little mechanical ability.
I tried to key start the engine but got nothing. When I checked the ignition it has 5 connections the BAT wire on the back of the ignitions is not connected to anything. Is this the ground and where do I ground it.
I found a schematic and it looks like it is suppose to go the solenoid but the wire is only 5 inches long with a loop at the end like it should be screwed into the boat frame.
I did turn the engine over with jumper cables and the starter does work and the motor turns over however the propeller was also turning when I had the controls in neutral. I am using a 12v car battery and not a deep cycle marine battery does this matter in the diagnotic stage?
You help would be appreciated
