reelfishin
- Joined
- Mar 19, 2007
- 3,050
Re: transom questions
I think he's got it right, the transom don't go to the very bottom on those boats. I believe their a Starcraft built hull too, very similar to an SS Starcraft.
I've done a few things when it comes to coating transoms. I also lay up a center layer of glass for added strength, and put a layer of epoxy and one layer of glass over the whole panel when I can, but if thickness is an issue, I just coat the whole transom with epoxy. I'd also predrill the drain holes and get those insides well coated, make sure you drill them large enough to accept some new drain tubes. I also seal those drains and all bolt holes with 5200 sealer. I pretty much assume that it's going to be underwater and shoot to protect the wood for that type of service. No wood exposed, no unsealed holes, and it'll out last you.
Keep in mind that it most likely lasted 30+ years with the minimum of care, so anything you do is a huge bonus for it longevity wise!
