1985 v150 carbs
wickedsix
i pulled all 3 carbs off to clean them. i know the middle carb is in the right place. is there a top and a bottom carb? or are they both interchangeable? i relized there were certain numbers on the top of them after i put them back on my motor.
j_martin
Re: 1985 v150 carbs
Depends on the engine. Somtimes the jets are a little different for different cylinders, and if you have an enricher valve, the top carb has the float bowl fitting to feed it.
hope it helps
John
Barnacle_Bill
Re: 1985 v150 carbs
The top carb will have the fitting for the enrichner hose on the bottom of the carb. The bottom carb will have that fitting on top of the carb.
