63 Starflite 85 hp gas coming out of the exhaust
Fuzzytbay
Re: 63 Starflite 85 hp gas coming out of the exhaust
Sounds like your floats is not adjusted correctly in carbs
bktheking
Check your fuel pump for a bad diaphram, you sure its a 63???
Maybe 68+
becheck
Im not real sure its a 63, Its on an old Glastron with a removable window.Could be a 68.Thanks Ill check the float
Daviet
Can you post your model#?
