15hp propeller problem
elevationzero000
i have a 15hp that i am trying to take the propeller off. i have to force the nut to turn and it looks like the piece the nut is threaded on to (prop shaft?) is turning also. i turned it just a little and noticed that. should i try to keep turning it? it is lefty loosy right? oh and yes i took the cotter pin out. the problem initially was while underway when throttled up the rpms would go up but not speed.? thanks for all the help!
deejaycee_2000
Re: 15hp propeller problem
loose is anti-clockwise ..... what motor is this yamaha or suzuki?
elevationzero000
yep, im turning it the right way then. the motor is a yamaha 15hp 2 stroke. model 15mshb
elevationzero000
Anybody? I am ready to get this thing back in the water for the weekend. thanks-
99yam40
might try to put motor in gear and pull the kill switch so there is no way it will fire up if you turn the motor and it fires.
I that will not help then a impact wrench would be my next thought. But be careful you do not want to hurt the gears and bearings
elevationzero000
i can hold the prop stationary, it is the rod the castle nut is threaded on to that turns with the nut. i am using an open ended 11/16 wrench so i can see the nut turning while holding the propeller with my hand. im spraying it with pb blaster too. i dont want to damage anything by turning it too much.
99yam40
by putting in gear , the shaft is locked into the motor and will have to turn the whole motor. Since the prop hub is slipping I do not know of a better way to put more strain on the shaft
