Suzuki DT-115 1999
pointbeach
Re: Suzuki DT-115 1999 will not start
I have A DT-115 1999 It starts right up runs for 2-3 sec. and dies ..
99yam40
do you have a question that you would like to ask?
What all have you done to the motor so far, and give a little history of what has been going on. Has it been setting up for awhile? When did it last run properly.
deejaycee_2000
Are you lifting the rev lever so it can fast idle until it is warmed up?
pointbeach
I picked up an 3 gal. gas tank.. I was told I may have bad gas.. it sense it not getting gas.. but gas is flowing to carb.. should I have my carb rebuilt?
You turn the key it fires up and dies in 1sec
Marion Moore
Wouldn't a 99 DT115 be electronic fuel injected or did they offer a carbed model that year?
Not sure about your question "how do I do this?". I'll assume you are taking about using known new gas from a tank. You don't even need the fuel bulb, I have taken a small tank filled with gas and inserted a hose from the fuel inlet on the engine. A good low pressure fuel pump will pick it right up.
pointbeach
Hay I just got my Dt115 EFI back I Needed a lower unit so $5,000 later. The boat run but it is hard the start. It turns right over runs and then stalls. If I have it in the water i can start and go but most of the times it stalls at low idel. So I need some help with a stalling at idel...
nash1970
My 1996 dt115 was doing the same thing it needed the carbs cleaned the E10 gas screwed them up .
