1966 95hp Thunderbolt Merc
Nickledimed
Can anyone tell me what the volt/ohm reading should be on a good coil for these motors?
We have one good coil that reads 10.91m.
We bought a brand new one and it reads 9.??m
What ever bank we put this good coil on is what we get fire from.
Bought a new one and it fails.
We can not seem to be able to get the right one.
usskydvr
Re: 1966 95hp Thunderbolt Merc
9 to 11 ohms. Did you check the ballast resistors? Each coil had its own.
Nickledimed
No I have not tested the resisters..but when I move the good coil over to the other side, everything works fine on that side.
usskydvr
Ok , then the resistors are probably good. What about the primary side of the coil resistance, should be less than 1 ohm.
Nickledimed
I will check that tomarrow afternoon. Thanks for helping.
Nickledimed
Just out of curiosity, How do you test the ballast resistors and what are the specs?
Thanks
usskydvr
Test the resistor(s) with no wires attached. Should be between 1 and 4 ohms, depending on the part #.
Nickledimed
Ok, Ill have to test those either fri or sat.
I tested the Coils and the new one was faulty, Secondary was 0ohms
Primary was 9.42ohms.
Also I noticed after looking at the schematics the wiring was all jacked up, the coils had been jumped on the possitive poles and the balist resisters had 2 jumpers instead of just one.
I think when we get a good coil the thing will run.
I be able to tell fri or sat also.
Thanks for all your help. Much appreciated!
