mxzeatr
Thread starter- Joined
- Jun 2, 2010
- 188
Most of the regulars will remember me I am sure.
Had a few issues in the past weeks after buying my boat/motor that I'm getting figured out finally.
When inspecting the oil system (pulled pump out to check plastic drive gear on crank), I found that the lines from the oil tank under the cowl, and the line from the fuel line to the oil pump were shot. I dodged a bullet I believe! I replaced them, then had a hard time bleeding the air out of the line from the pump to the fuel line. Thanks to JMartin I got that on the first try after his tip! So I bled the oil pump again and carried on, I replaced the rubber o-rings on the boat tank, and ran the motor. I had oil pressure in the tank, so figured the checkvalve was ok. When I put the boat in the water the first time this weekend, I bled the oil tank under the cowl, I couldn't do that on the trailer because the motor is too close to the ground to get level. So all is well. Ran around the lake for 35-40 minutes and when slowing down from WOT my oil alarm turned on. So I beached it (gas was 50:1 in tank BTW) and began looking things over. I had read to change the wire for the alarm modual to a diff. cylinder number on the switch box to see if an engine miss was causing the issue. I did that, went from #2 to #3. No alarm while pulling skiers for about an hr, boat ran flawlessly. Swapped passangers and embarked on a 1hr idle up river, alarm on/off the entire way, motor smoking like mad, got out into the lake and drove it for another 2 hrs total (not all at once) and no alarm. Then it came back and was on almost the entire way thru the river, out in the lake it was off and good to go.
I marked the boat oil tank with a marker, I used approx 18 gallons of gas, and about 1.5-1.75" of oil out of the tank. Which is plenty I'm thinking. Cowl tank was full with no air in it, lines are full with no air, etc...
Sunday I put gas in the boat and didn't mix it. I know its getting oil. Ran the boat down the big lake for 10 miles with it on and off, sat for 6hrs at the party spot, then fired it back up, alarm was on most of the way up the lake, then have to idle to launch, it shut off and stayed off for the rest of the day.
I know I know...I need a book, I've tried to find a merc one online, I can't find them anywhere, I've also read that I don't really want a seloc one???
I tried to unplug the cap wires and the rotational sensor wires while the alarm was on, but I'm assuming that wouldn't make it shut off anyways? It didn't seem to change a thing.
Alarm modual shot? I've tried to check all the wiring I can, but can't rule out a loose connection, I just don't know what to look for. A piece of tape makes the alarm tolerable at least.
Sorry for the long post. Wanted all the details I could give to you guys in there.
Thank you!
Thank you!
