eska /ted williams 15 hp specs
truckintyler
can't find what i'm looking for. wondering what rpm's they run at and how much the spark would advance on them or generally any outboard around the same hp
i have an idea on a fix for the ignition well a new one, i'll share when i've got it running
M
mrcrabs
Guest
Re: eska /ted williams 15 hp specs
If its any help the single cylinder cranks out 7.5 hp at 5650 rpm, I would guess that the 9.9 and 15hp would be in that rpm range but I just checked and 1963 10hp johnson has a max rpm of 4500 so your probably looking at 4500-5500 which is typical for a 2 cycle outboard.
truckintyler
any idea on the general spark advance? how many degress total it need to get to at full throttle
M
mrcrabs
Guest
I have been looking for some more info on the 15hp and if I run across it I will post what I find.
don't concern yourself with spark advance on these motors. this is controled by the flywheel weights which turns a plastic donut with a magnet on one side. timing on these motors can be altered only a small bit by turning the stator on the oval holes. best bet is to set them in the same spot as they were. you can usually tell where by the screw marks on the stator plate.
jefrdu1
I need to know the procedure on how to check the timing and set the stator plate, I don't see the marks where the plate was in the first place. The magneto (cdi) was taken off the engine when I got it. The only manual I could get only refer to the one cylinder type.
Thanks in advance for any help.
