sloppysbar
Thread starter- Joined
- Jul 6, 2010
- 3
Ran the boat, ran fine no matter what RPM. Then the motor came down of step and ran sputtered. I came home and found a lot of water in the tank. I drained the tank, blew out the lines, changed the ravoc fuel filter. Filled the boat up, put in two cans of sea foam and changed the pump up ball. Boat ran fine for about 1 hour. Then started acting the same way, then gradually got worse to the point that it would not run over 2600 rpms. Long story short, I floated home for about 8 hours. Any suggestions as to what is going on? Thanks for any input.
