OK, folks. Here is the scenario. This year when I put my fishing boat (Sea Nymph Great Lakes Special, 90 hp outboard) in the water for opening day of bass fishing, it ran fine and everything was good. But I had one problem. My Garmin fishfinder/GPS unit would run fine and then power down after a few minutes. After opening day, my schedule went berserk and I did not get a chance to put it back in the water until yesterday. It ran fine, but when I went to turn on the lights at dusk, they came on for a second and then went out. No amount of prodding or reinserting them would get them to come on. I pulled the boat, and today I went out to track down the problem. Before I started, I put the lights in the fore and aft sockets, walked up and switched them and they came on fine in both positions. Thinking it might be related to when the engine is running, I put the earmuffs on, turned on the water, and started the engine. The lights were fine. Worked in both the running and anchored switch positions. So I put the boat in the water to go troll for walleye. First thing is the Garmin would not even come on. Then I attempt to turn on the running lights, and they flash and then nothing.
Several years ago I rewired the boat and put in a fuse block. The Garmin also has a switchable power supply. I also have a Perko switch with the two batteries.
My inclination is to start with the wiring to the fuse block, although everything else (dashlights, etc) work. The engine starts fine, but that is direct to the battery. I also wonder if it is ground related. My bet is tomorrow, after the boat sits in the garage and drys out overnight, the lights will work again. That is what happened the first night.
So, all you wonderful Sherlocks out there, where would you start and how would you proceed? Wiring isn't my strong suit, but I know enough to be dangerous.
Thanks,
Mick
Thanks,
Mick
