BoatNoobie
Thread starter- Joined
- Jun 17, 2009
- 314
got a Lowe FM165 with a Merc 60HP.
How do I set it up?
How do I set it up?
Short answer don't do it. Too much stress.
look in the marine store, what you'll find (I think they still make them... is a rope with 2 clamps, the rope is a floating rope, you clip each end of the rope onto that transom tie down hook on each side of the stern.... and on the "loop" of the rope, is a floating pulley.... and the pulley can slide around the "loop" .... and the tow rope is connected to the pulley...
the set I have, was given to me by my dad, and it's gotta be 30-40 years old, and I still use it. Never got caught in the prop, as it all floats, just gotta take up the slack till the rope is tight before popping out of the hole.
This works great for tubes, but if you get into skiing, you will wish you had a pole or tower i am sure. We ski with the rope setup I have, but it tends to "pull down" whereas a pole or tower would pull up...
sorry don't have a pic, or I'd post it - but can take one if you need to see it
The only time I could actually see stress happening is if you were towing a tube with loads of people on board.
