89 Johnson 88hp Ignition switch diagram
lindalee
:( Ignition switch diagram. someone put a new Ignition switch in for me. the boat will not start they say it is a electrical thing :( will I look at it and I found some wires not hooked up,and it would not start, I changed the spark plugs and some other things and still won't start :confused: also need the schematic for the wiring to the motor and under the dash. Thank You
Bob_VT
Re: 89 Johnson 88hp Ignition switch diagram
welcome to iboats
I will give this a try but the diagram I have is for a 1983 but, I think it may be the same ;) but it is too large to upload. send me a Private Message.
