kill switch wiring 1980 20hp evinrude
stonecobbler
Hi Experts
On the evinrude i just installed on my boat has 2 wires that are twisted together with a cap on the end i am assuming that is active and when i pull the wires apart that would kill the engine, So if that is the case i should be able to run those cables to the front of the boat to a wrist kill switch, Please let me know if i have that right.
Thanks
Wayne
stonecobbler
Re: kill switch wiring 1980 20hp evinrude
I'm surprised nobody knows the answer to this one
wbeaton
Its not that nobody knows the answer its that nobody knows what those wires are. There should be absolutely NO marettes under your hood. Also, normally the switch works by touching the wires together not pulling them apart. Who knows what you have going on under there.
mike1245
it will help to know what color the wires are?
stonecobbler
ah,,i understand
so these wires are on the outside of the motor that is why i think they are active when they are twisted together as that is how the motor came when i bought it,,,if you need to know what color they are i could take a picture if that would help.
thank you
Wayne
jtexas
if it's a color picture, it might help. Unless the wires are dirty/greasy/faded. A description might help as well.
Fed
If you could trace those wires back and tell us where they come from would also be a big help.
stonecobbler
It looks to me like both wires are black,,,or really dirty,,,,my motor is a pull start non tiller with a large black push button kill switch just below the pull cord and next to the choke,, i would imagine these wires are also linked to that button somehow for ability to run a kill switch to the front,,i guess one way to find out is to start the motor in a barrel with wires together and then again with them apart. Sorry no pictures because i can't find camera usb cord at the moment but i don't think it would help anyway.
Wayne
Chinewalker
What model are we talking about here? Not familiar with a 20 that has the pull cord down low with a kill switch button just below it. A model number would help us sort things out...
stonecobbler
j20crcsa says johnson 20hp 1980 canadian rope start but has an evinrude cover
hope this helps
jtexas
de-rated 25 rope start. definately not the kill circuit.
can you trace the wires back to their starting point?
stonecobbler
So i emailed the guy who sold me the motor and he said that if those wires are not touching the motor will not run, so i'm guessing he put those in aftermarket.
Wayne
wbeaton
Did you ask what the wires were from/to?
jtexas
hmmmm.... a self-engineered solution.
Can you trace the wires back their starting point?
stonecobbler
here are some pix of the wiring,hope this helps me out,the last picture is the boat project,,,,,,boat and trailer $200 motor $500 6 year old son helping re-do of the inside,,,,,priceless!!!!!
jtexas
it's a ground wire all right. looks like it's coming from the power pack. I thought I knew something about OMC wiring schemes of the 1980's, but I can't identify the purpose of that wire.
I can't believe you get to rebuild a boat with your son...I'm jealous...
stonecobbler
Are there any wrist band kill switches that work in the wire configuration i have or should i just do a toggle switch at the front,,,i prefer the wrist for safety,,any ideas wouldbe helpful
Thanks
Wayne
jtexas
the aftermarket safety lanyards at Academy Sports, BPS, etc that I've seen, work the opposite of what you need...other words, they're all "open to run, closed to kill". I bet if you look around you can find a contrary one...
