I purchased a boat earlier in the year that has a 1989 classic fifty that I'm trying to get running. This is my first outboard so it is a learning experience so bear with me it I provide too much detail. I've gone over the motor top to bottom and done the following:
- Removed the carbs and cleaned every jet, port, etc. multiple times and reset the floats (doesn't mean I did them right). Replaced the gaskets and washers. Did NOT replace needles or remove any parts while cleaning other than the bowls.
-Pulled the lower unit and changed the water pump
-Changed the lower unit oil, no sign of water
-Checked the spark, all ok (did not check the voltage, just that there was spark)
-Checked the compression, 110 on all 4.
-Removed the oil injector
-I set the mix screws in the front to 1.5 turns out and it started with some coaxing but I ended up backing the screws out another 1.5 turns each and that allows it to idle and start up pretty easy. I can rev it and back it down to an idle without a problem. This is all in a barrel, not with muffs.
- I'm running 40:1 with mercury quick lean
- I replaced all the fuel lines and filter
- I rebuilt the fuel pump
- I have a new tank fuel line, bulb and motor end fitting
- I replaced the plugs
The problem I have is when I put it into gear. Most of the time it just bogs down and stalls. One time I was able to get it to run at an idle in gear for about 30 seconds but generally I had to take it back to neutral to prevent of from stalling. I have been able to get it to run in gear with the muffs so I seems to be the load of being in the water.
I noticed that the fuel filter is only about 1/3 full but seem to stay at that level, is that normal?
I pulled the plugs and they are all wet with some black residue after running
Any suggestions on getting her to run in gear?
Where are all the adjustments on the carbs? There are two to the upper right of the intake. Are there any other adjustment screws. I keep hearing about an idle set screw but can't identify it on the motor.
Background: This motor was sitting outside for a while. The person before me was having a problem getting it to high RPMs. When he would take it to the shop they would hook it right to a can and not have a problem running it. I found that one of the lines was too big for the fitting on the oil injector and leaking air so I took the injector out, not to mention that I saw many posts recommending the removal.
The carbs have the square intakes on the sides with 4 screws and the bowls are round except for an indent on one side.
There is a horse shoe shapped plastic piece on the top and when looking from the front of the motor the opening is on the right. Since idling is working I assume I have that right. I did not take it off when cleaning
I haven't checked anything on the ignition, mainly due to a lack of knowing how.
Any suggestions?
Thanks in advance!
Any suggestions?
Thanks in advance!
