Robalod3valles
Thread starter- Joined
- Jul 7, 2010
- 3
Hi there!
I have a 96 Johnson 88 hp, I have to replace the water impeller, so I have to remove the lower gear unit. I got all bolts loose but I have to disconnect the shift rod linkage. The problem is that I cannot find the exact location to disconnect the linkage. I move the linkage to reverse and the unit seemed to separate more, but the rod must be disconnected in order to work on the water pump. Does anybody know how to takle this problem? is there a trick to it? Any special tool for this? Please help , I want to use my boat this year!
Thanks!
Thanks!
