Re: Total Hours Question
I know that low hours is not a good feature for an outboard; they need to be run often. Is the same true for inboards, experts?
I use the service manual schedule of "1 year/100 hours" to assume the manufacturer's expectation of 100 hours a year. That's where I am. It also indicates that service is needed even if it sits.
Crabbers and other commercial users may go 1000 hours a year. They replace engines every couple of years.
I see 400 hours in 23 years as not being used enough. 17 hours a year? Why would someone maintain correctly a boat he never uses? Why change the plugs and filters after 17 hours (3 day's of boating)? (Answer: because they have been sitting). To me, the "hours" would have some significance in a boat less than 5 years old; after that, except in extremes, probably doesn't tell you anything about the motor--but it tells you a lot about its use.
OTOH in parts of the country with short seasons, and if stored correctly (big if) you get a little "time capsule" effect. But the 23 year old boat in the salt and sun here may have as many, but different, issues as the 23 year boat in the Minnesota winters.
There are parts of boats that deteriorate with age just sitting there, so your 23 year old boat has 23 years on the parts regardless of what's been going on inside the engine block. In that respect hours are indeed meaningless, or more aptly put, a distraction.
