Re: 73 evinrude 115 v4 misfire
That could be from several causes including a fuel pump unable to keep up with the demand or ignition coils breaking down when heated.
If you are using fuel supply components of less than 5/16 ID, you may want to upgrade.
If the ignition coils are cracked, discolored, swollen or if the potting material is distorted, it would be a good time to replace them before they destroy your powerpack.
Check your fuel supply carefully for air leaks as well.
