4WinnsH200SS
Thread starter- Joined
- Jun 2, 2010
- 5
I bought an '08 Four Winns H200SS in which the previous owner upgraded the stereo system by adding two big bazooka amp?s, 3 10? Kicker Subs, and four Bazooka 6X9 Marine Triaxial speakers. When he did this an additional battery was installed which allows for running on Battery 1, Battery 2, Both, or Off.
I left the switch on over night while at the lake, and one battery seemed low the next day and seemed to stay weak. (The stereo would not operate the next day at any volume over about 10%, and sometimes not all.
When I got home I took both batteries out to have them tested. Both batteries tested fine.
I reinstalled the batteries and I have no power to anything.
Here?s how the boat is wired?
The positive from battery 1 goes to the ?in? on the battery switch 1.
The positive from battery 2 goes to the ?in? on the battery switch 2.
The negative from battery 1 goes to the negative on battery 2.
There are two clear cables that are taped with black tape that come from the stereo that attached to the negative pole of battery 1. The ONLY thing I could have messed up when hooking the batteries back up are those wires from the stereo. Could they have gone on the positive pole?
From the ?out? on the battery switch:
-two blue heavy gauge wires that go up to the stereo rig.
-a thick red wire which goes to the engine
-a red wire with stripes that goes to a 30 amp helm power breaker.
From the helm power you a red-striped wire that goes to the fuse box at the helm.
I have checked both batteries and they are fine. I have checked the helm power breaker and it is not blown. I have also checked every fuse in the boat and they all appear fine.
What in the world is going on?
In advance, Thanks!
In advance, Thanks!
