1980 johson parts diagram
fmalott
as i mentioned in other post i have a 1980 seahorse 25hp. i need a parts diagram i'm not sure if it's called a parts catalog it's a expanded view of the motor. as i was taking motor off boat i damage the rod thrust and retainer i'm sure you know what it is it's part of the pivot for different levels oh! it's a manual pivot i need parts number to order new one i can not find anywhere
Rscardina
Re: 1980 johson parts diagram
ps..when you get to the page..on the right see parts catalouge...click it
then it will open up a view of folders with years..make sure the top right just under "parts" is on Johnson..or hit the arrow and you will get a drop down to chose Johnson...
find your year, HP and then model and you will what you need.. I think the part you want is in the exhaust housing diagrahm..
Vic.S
Or the link to the electronic parts catalog from http://shop.evinrude.com/ It always seems to work better than the BRP one. Tells you prices and availability too
Also www.boats.net in a slightly different format
fmalott
thanks i will give both a try
