1959 Hiliner 16'; advice on small crack in top of transom
mike_ct
so just picked up the boat (no motor), hasn't seen water in about 25 years..i got a 1969 50hp merc running i had from another project and set it up. when home from my first trip out, i see a long crack in the transom, i'm assuming from the weight of the motor back there. i'm guessing it happened from trailering the unit to and from, and not from the trip down the connecticut river. so i invest in a "transom saver" shock absorber type from cabellas and fit it to the motor and trailer for towing, and i sand down the cracked area, dig at it a little, and start applying some polyurethane to seal it up. it is very solid, and doesn't have any flex.
am i missing anything and should i be doing anything else to prevent this or repair it? also its the original trailer i am told, and although it is sound, its nothing like the sturdy new trailers they make now adays..
i can't find much info on the older hiliners, although it should just follow the same rules as other wooden runabouts, right? do i need additional bracing or a plate to help distribute the weight from the motor instead of just the two circlular outboard clamps & two lower bolts? i am using a 3/8" spacer on the outside of the transom as shown, but its just to clear the wood trim on the transom water line. i also added a piece of 5 x 28" aluminum 3/16 bolted in 4 places and motor clamped over to give some additional bracing and spread out the 2 clamp circles..
patpel
Re: 1959 Hiliner 16'; advice on small crack in top of transom
Hi Mike.
Welcome to Iboat.
That's a real beauty you have there.
I don't know anything about the trailer, but as a professional cabinetmaker I can advise on the woodwork.
From the picture, it looks like a plywood delamination split.
I would scrape and sand back to the wood where the damage is and fill it with colored epoxy then reapply the finish.
It doesn't look like much in any case.
cheers
patpel
mike_ct
that was quick! thanks for the welcome and the woodworking advice! will give it a go..
vegasphotoman
I would say the same...solid advice! Hey SWEET BOAT! that transom saver is a no brainer and would reccommend it to everyone..:D
floatdesign
Refer to our rules to determine how many you have violated. JB
Jay
