Re: 83 Johnson 115 hp No start help.
Confirmed No spark from any of the 4 coils....where do i go from here?
It is highly unlikely that all the coils failed at the same time. Do you have a fully charged battery? The motor needs to spin at least 300+ RPM?s before it will make spark. Then check to make sure the kill/lanyard switch is not disconnected. If both of those check out verify you are getting power to the power pack and verify if power is going out to the coils. Post results.
1. Disconnect the black yellow kill wire and retest. If the engines now has fire, the kill circuit has a fault-possibly the keyswitch, harness or shift switch.
2. Disconnect the yellow wires from the stator to the rectifier and retest. If the engine fires, replace the rectifier.
3. Check the stator resistance. You should read approximately 1000 ohms from the brown wire to the brown/yellow wire and 100 ohms from the orange to orange/black.
4. Check the DVA output from the stator. You should have a reading of at least 150V or more from the brown wire to the brown/yellow wire (while connected to the pack).
5. Check the timer base resistance from the white wire to the blue, green, pink and purple wires. Reading should be 38-42 ohms.
6. Check the DVA output from the timer base. A reading of at least 0.5V or more from the white wire to the blue, green, pink and purple wires (while connected to the pack) is needed to fire the pack.
7. Check the cranking RPM. A cranking speed of less than 250-RPM will not allow the system to fire properly.
You will need a DVA for #4 AND #6, If you do not have a DVA, you can order one here:
http://www.usatoolwarehouse.com/usat...e/ESI-640.html
