VRO conversion
Daviet
I thought I have seen a list of fuel pumps to convert the VRO to premix. I can't seem to find them, anybody remember where it might be posted?
Daviet
Re: VRO conversion
Thanks
I found that post but the fuel pump list at the bottom of the page will not come up, says it cannot be found.
wilde1j
Re: VRO conversion
25 to 75 HP
Sierra 18-7352 only two hose nipples, in, out, pulse from the back.
Sierra 18-7353 has three hose nipples, one incoming fuel, one outgoing fuel and one for the hose for the pulse
papajorgio01
Re: VRO conversion
When remove the oil tank to my vro pump and premix my gas do I have to reconnect the wireing in order for my fuel pump to work?
d.boat
Re: VRO conversion
The wiring coming from both the fuel pump and the tank is for warning signals only. They don't have anything to do with pump functioning. Leave them disconnected - but make sure the wires you disconnect them from (inside the cowling) are tied off and/or wrapped in tape so they won't rattle around or ground on something metal (which would cause a false alarm).
docdoc88
Re: VRO conversion
25 to 75 HP
I am trying this same conversion on a 1989 vro 60hp. On the page that sells the 18-7353 ... it states that it is for a 20 to 30 hp 1990-2000 engine. Are you sure it will work for a 60hp ??? I bought the 18-7352 by mistake and it will not mount on engine ( no external pulse line ) I want to make sure it will supply enough fuel. Thanks
cday
Re: VRO conversion
I'm also about to replace the pump on a 1990 90hp. Will the 18-7353 work for me as well or will I require a different one?
freetime99
Re: VRO conversion
I replaced the VRO on a 99 Johnson 60hp -3cly. with a Bombardier pump assembly, part# 0438559 ( has seperate nipple for pulse) and it works great. Someone on this forum gave me that part# last year. This pump does a better job of supplying fuel ( mixed by me of course ) than the VRO ever did.
