SwordsBeginner
- Joined
- Jul 10, 2010
- 28
Hi all, I have a 2 stroke Evinrude 70 HP engine, which came with a boat I purchased. The engine is circa year 2000.
The boat/engine was lying up for a while before I purchased it, but the engine started fine. I had a marine mechanic look at it before I went on the water. He cleaned carbs etc. and said engine was in great condition.
This engine ran/idled fine with muffs on.
However on the water, I have been out five times now. everytime I have a problem with the engine dying on me on increasing revs (slowly *).
After the second trip I went back to the marine mechanic to ask about this and he increase the idle speed. But this has not solved the problem.
* If engine running at idle in water and I increase throttle slowly the engine will die, however if I put the throttle down quickly and get the engine to a high roar the engine will not die and the boat takes off (quickly). I can decrease throttle then to a reasonable rev.
I have changed fuel tank, hose and this made no improvement.
PS I did notice today that the throttle cable flexes/moves when throttling.
Any ideas?
Any ideas?
