1967 9.2 chrysler no spark (top cylinder)
LEROYDOZOIS
I WAS FINALLY ABLE TO GET THE BOAT OUT ON THE WATER TODAY!!! IT WAS A BLAST EVEN THOUGH THE BOAT WOULDNT PLAIN "TOO MUCH WEIGHT IN BACK"
THE MOTOR WAS RUNNING REALLY GREAT "WOT" AND I DECIDED TO TURN BACK TO GO IN THE MARINEA,
THE MOTOR STARTED STUTTERING AND I THOUGHT IT WASN'T GETTING FUEL "IT WAS" THEN I THOUGHT IT WAS FOULING A PLUG "IT WASNT"
BUT AFTER LIMPING IT BACK TO THE SHORE I REALIZED IT WASNT THE PLUG, BUT NO SPARK GOING TO IT "PLUG IS STILL GOOD"
I LOOKED FOR THE WIRE BEING PINCHED ANYWHERE AND IT WASNT :(
SO IM GUESSING ITS SOMEWHERE-SOMETHING IN THE COILS :mad:
JUST POSTING THIS TO GET SOME IDEAS OF WHAT TO LOOK FOR,
ILL BE HEADING OUT IN THE THE GARAGE TO CLEAR THE WORK AREA :rolleyes:
THANKS FOR YOUR TIME GUYS !!!
LeRoy
jerryjerry05
Re: 1967 9.2 chrysler no spark (top cylinder)
You switch the plug to see if it's good?If it's still not working then,do a compression test.Then remove the flywheel.The points could be corroded.
Clean them with sandpaper.Don't loosen anything till you do this.Try cleaning the points then if that won't work you will probably need new points/ condesers.Get a manual to do it right.J
