Leaking Mechanical Fuel Pump
Dobb15
I noticed a rainbow when my bilge turned on, so i checked for fuel leaks and found a dark liquid dripping from my fuel pump, is this oil and gas mixed>>?? or just oil?? i have removed it and the gasket between the pump and motor (where it was leaking) is worn so i will replace it, anything else i sould look at or fix that this may have caused??
jtmarten
Re: Leaking Mechanical Fuel Pump
Most likely just oil from the bad gasket.
Dobb15
Would any Fuel have gone into the oil??
jtmarten
Some fuel gets in the oil all the time through the cylinders. If the fuel pump diaphragm was torn, I guess it would be possible to get some in the oil, although unlikely.
