can anyone confirm if this bracket is designed to support the weight of this motor?
new to the forums, but reading here it sounds like this engine should have a lift point under the hood?
I am hesitant to hook to it and lift, seeing that it appears to bolt to a cover, which is then itself bolted to the engine block. I would be really unhappy if I had to buy a new endgine block because I tried to lift my motor by some accessory cover or cable guide bracket.
Any advice would be appreciated, more views of the bracket and surrounding area, below:
