Re: Opinion on mid- 80 50 hp merc
Its better IMHO than that evinrude 50 you had, however, I would make sure you test out the compression on the motor before you buy it. If you don't know how, then bring someone who does. The last thing you need are two boat anchors. Also give it a good look over, ie, does the skag look like it and a hard object have meet in the past. HOw does it look under the cowling. Greasy oily, paint off the bolts, lie someone has taken it apart, that sort of stuff. Pull the drain plug on the bottom end, and look at the oil. IS it black, brown, white? Does the screw have metal shavings on the magnet portion of it?
