FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
I just replaced the impeller ... the lower unit went back on well, but now it is stuck in forward. No neutral or reverse, I redid it and tried to make sure the shifting level got ok but no change.
Make sure your lower unit is in neutral and your shifter is in the neutral position. The LU is in neutral when the prop spins freely both ways. Turn the shift shaft on the LU CCW to put it in neutral
Also, You'll know you're in reverse if the prop is locked when you turn it either direction. Forward should be locked in one direction, ratchet in the other.
Also, make sure the upper and lower shift shafts lined up and engaged each other when you slide the lower unit back on. I had a tough time doing this and had it apart several times. What I found was there was a hole in the front of the lower unit near where the bolt goes through. I could just reach in this hole with a screwdriver to hold the shaft in the right spot while sliding it together. Good luck.
Got it together about 30 minutes with my wife trying to keep the shift shaft straight went in so smooth .... but unfortunately the upper nut has to go on before it is completely together.
So take apart and another 15 minutes and it is now together and shifting properly.
