Help with broken bearing buddy
ab1
I went to fill up my bearings with grease and when removing the gun, the zerk fitting came with it. I could hear air escape as the spring plate collapsed inwards. I assume this cannot be fixed so I will be replacing the BB's at some point.
In the meantime, I need to take a trip of about 100 miles. Can I just knock off the BB on that side, hand pack with grease, install a dust cap, and then be on my way for a week or so. I'm not all that familiar with trailer bearings and maintenance. Any specifics on how to do this correctly will be very much appreciated!!! This was my first time filling the BB and it seemed to go well until I pulled the gun loose and the zerk fitting popped out.
Thanks!!
j_martin
Re: Help with broken bearing buddy
Throw the bra on it and make your trip, then replace the bearing buddy, or else just pickup another set of bearing buddies, knock this one off, knock the new one on, lube it, and yer in great shape. Then you have a spare to throw in your tow vehicle in case one gets knocked off or stolen in the ramp parking lot. (it happens)
The bearings need grease, but not pressure unless you're immersing the hub.
hope it helps
John
ab1
Thanks for the links and the advice.
John, if I understand correctly, I'll need to replace before I head out. I'm trailering the boat and plan to launch it...so the hub will be submerged for a short time.
HappierWet
The bearings need grease, no question. But I will argue about needing pressure.....they're not under pressure when only using a dustcap.:)
That said, I believe BB's do a better job of keeping water out.;)
ab1
Thanks, let me ask you this since I'm totally new to bearings.
Is there a way to tell if the bearings are greased up properly? I just got the boat not too long ago and thought I would pump them full as maintenance but then the zerk busted off. I don't know when the last guy replaced the bearings or even filled them or topped them off. My plan is to put a new bb on there and fill it up before I go. Is it necessary to remove the bearings, repack, and regrease...or will the new bb (once full) add the appropriate grease if needed?
With the bb removed, I can see the cotter pin/nut and there doesn't appear to be any rust, just some excess grease which looks a little old and grayish. It appears pretty clean overall.
j_martin
The bearing buddies work by applying a slight pressure to the grease in the hub, so that when the grease contracts by being cooled quickly (launch time) the spring loaded diaphragm keeps a slight pressure on it so it doesn't pull water in past the grease seal. That water intrusion is the #1 failure mode for boat trailer wheel bearings.
When using a dustcap, you need to frequently service, often replacing the wheel bearings. With bearing buddies properly maintained, service intervals can be stretched out to years, as water intrusion is not a problem.
Notice my explanation above. You described pumping a bunch of grease into the bearing buddy, then hearing air escape when the zerk broke off. That suggests that the bearing buddy was installed, but never serviced as it should be. It should have systematically puked grease all over your toes. You have the same dust cap problem I described above.
It looks like it's time to pull the hubs, replace the seals and repack or replace and repack the bearings, and install new bearing buddies. Then you grease them (follow the directions) frequently till the hub is tightly full of grease. Usually takes a dozen short trips and dunks in the lake. After that, if the seal is in good condition, the only service needed is visual inspection each trip.
I pack my wheel bearings with the same marine grease I use on the outboard. I buy it in small tubes at wally world, and keep a small grease gun handy loaded with it.
For now, if you're in a hurry, and the wheels turn smoothly with no excessive play, a strap of duct tape over the cleaned end of the bearing buddy will get you by for 1 trip.
hope it helps
John
mla2ofus
If your BB's are like mine all you need is a 1/4"x 28 nut on the threads of the zerk on the back side of the plate to hold the zerk in the plate/plunger.
Mike
