Marine engine vs. Car engine?
Doernuth
So I need to replace a 1977 Merc 165. This is a GM 4.1L 250ci I6 engine. What is the difference between the marine and automotive version? I have a line on a used car engine that runs, can I use it or do I need to pay much more for a rebuilt marine engine?
greg82255
Re: Marine engine vs. Car engine?
Marine engines have different starters, alternators, distributors, carburetors, and it is dangerous to use any of those auto parts in a marine application. They can cause sparks and ignite any fumes in the bilge.
Kainon
I actually have an engine from a '74 NOVA that the PO put in, the main difference in mine was the camshaft, the Marine has a little more lift & duration. also the mount on the front of the marine block for the RH side of the front mount, isnt there on the auto/truck block so my PO made a peice of alum, If you PM me, I might be able to get you a closer pic.
You'd need to use the electrical components as mentioned from your current engine, DO NOT USE THE HEI DIST !!! - its not safe.
You need to also pay attention to the year of the cylinder head and if it has Hardened Exhaust Valve seats, Pre-HEVS Heads needed LEADED Fuel to keep the Exhaust Valve Seats cool and from sinking into the head.
What's wrong with your current engine ?
zbnutcase
If that car engine has more than 20k miles on it, it will need rebuilt before you can use it anyway, so you might as well rebuild yours
jaxnjil
i have ask..... you peaked my curiosity
why would a auto motor in good running order have to be over hauled before using in a boat????? regardless of milage
Doernuth
Update, I bought a boat to get the engine. a 165 merc that runs well. Now I just have to transplant it to the boat....
mcleaves
The difference is a lot more than the boltons (alt, starter etc) needing to be marine certified. You will need a different cam. If you get your hands on a truck engine you can start with that as a base. Also if it's not a closed cooling system (ie. it's a raw water cooled system) you will need to have brass freeze plugs, a marine water pump etc. Anything inside that engine that will touch water.
M
