Hello folks, I recently hit something and messed up my prop. The hit took a small piece about the size of a half of a quarter out of one of the blades, which certainly threw the prop off balance. Later on I found a 1-1/2" or so crack in the lower unit. I don't think it was there immediately after I damaged the prop, but it may have been. Or could it have been caused by running the engine with an off-balance prop causing excess vibration? What do you folks think, how serious do you think this crack is and should I be overly concerned about getting it repaired immediately? Of course, I'm getting a new prop before running it any more.
Thank you for any input you may have.
Below is a pic showing the area of the crack in red. This lower unit is not my lower unit, but it's similar and shows where the crack is.
