ekmanspiral
Thread starter- Joined
- Jul 6, 2010
- 21
I drained the upper gearcase last night and found mostly water in there. Where is it likely that water would enter? I was looking at the manual and it looks like the water pump pumps the water up to the upper gearcase and then out the sides where there are diagonal passages connecting to the pivot caps - is this correct?
I filled the gearcase with 30w to soak everything and when I checked it this morning it didn't seem to be leaking. Of course its a different story when the shafts are turning and the water is pressurized.
All the seals visually look fine. Any idea of the likely source of the water?
Thanks,
Neil
Thanks,
Neil
