Dear Fellow Boaters,
When I had the lower unit on my 85 HP serviced I had a new water pump and thermostat installed. When the lower unit is mated to the leg, the cooling water tubes fit into neoprene tubes and a gasket is fixed to the internal mating flange of the lower unit that fits against a companion flange inside the leg.
My problem is I get zero cooling water out of the two exhaust ports on the upper part of the leg, but water is squirting out the flange between the leg and the lower unit. The engine runs fine, but I know this is not the design solution. What have we done wrong in assembly or are we missing the obvious??
Thanks for your help. Troubled in Ohio.
Chuck
Chuck
